Re: Should I worry about rear axle bearings in my Super M???
Posted by GordoSD on August 17, 2011 at 17:41:23 from (216.106.246.88):
In Reply to: Should I worry about rear axle bearings in my Super M??? posted by Mike1972chev on August 17, 2011 at 17:07:16:
I have had two outer axle bearing failures and one inner. They always tell you very early. When you hit the brake on the bad axle the tractor will"lurch" or jerk and then "release" If you can get on the brakes hard with no wobbling then you are good to go.
