Re: Should I worry about rear axle bearings in my Super M???
Posted by randy hall on August 17, 2011 at 17:44:10 from (98.102.151.18):
In Reply to: Should I worry about rear axle bearings in my Super M??? posted by Mike1972chev on August 17, 2011 at 17:07:16:
if you want to check something take the brakes off and then the backing plate and pull the bull pinion out and look at their bearings. many more pinion bearing failures than axle bearing failures.
