Re: Engine rev after carb overhaul continued...with pics!
Posted by 504 on August 17, 2011 at 20:07:35 from (64.111.61.44):
In Reply to: Engine rev after carb overhaul continued...with pics! posted by Sean0918 on August 17, 2011 at 09:03:12:
There is one other thing I have done so I know it can be done, if the air horn is upside down it will run wide open. (the throttle plate hits it and it can t close.)
