Re: Should I worry about rear axle bearings in my Super M???
Posted by pete 23 on August 17, 2011 at 20:30:43 from (74.32.234.149):
In Reply to: Should I worry about rear axle bearings in my Super M??? posted by Mike1972chev on August 17, 2011 at 17:07:16:
With old worn bearing you may very well find looseness, but, I have seen a jillion bearings fail with busted balls and brinneled races that were tight as new. Another thing, the inside axle bearing may possibly been replaced with the bower flat roller used in late 560 and it has considerable end play and some up and down when new. This can throw you off. What I am saying is only way to really know is to have the bearing in your hand and inspect it. Just took a inner axle bearing out of a 1086 today that was tight as new but several rollers were in very bad shape. Of course they are tapered rollers and have a preload.
