Re: Magneto to Distributor Conversion...
Posted by El Toro on August 18, 2011 at 04:09:58 from (108.15.86.54):
In Reply to: Magneto to Distributor Conversion... posted by Stemmy on August 17, 2011 at 20:45:59:
third party image
You can convert your existing mag to a distributor by disconnecting the coil wir ein your mag that goes to the points. Install your auto type coil and if you're going to use 12 volts run a wire from your ignition switch to the + terminal on your coil, then a wire from the coil's neg terminal to the points. You need to run battery voltage to your ignition switch and disconnect the grounding wire on your mag. Hal
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
