Re: Should I worry about rear axle bearings in my Super M???
Posted by Mike1972chev on August 18, 2011 at 05:58:55 from (75.149.81.173):
In Reply to: Re: Should I worry about rear axle bearings in my Super M??? posted by CenTex Farmall on August 17, 2011 at 21:51:11:
Yea,I did think I would unload the weight off of the rear axles and Take about a 6 or 7' bar and pry around on them for movement.It seems to me also,if the OUTER bearings were going bad,the axle bearing retainers would be "grinding" into the axles themselves under the load???
The seals are not leaking and I do use those grease fittings on the axle bearing retainers about every other trip out with it.
