Re: Disc Brake work on My Super M Farmall.Getting them to...
Posted by DeltaRed on August 18, 2011 at 06:45:29 from (174.16.71.96):
In Reply to: Disc Brake work on My Super M Farmall.Getting them to work ! posted by Mike1972chev on August 18, 2011 at 06:16:27:
Yes you can mill the"hats".take the 'guts' with you and measure with a syraightedge to find how much to take off.IFIRR,you should have about 20,ooo gap.then you will have to shim the bolt heads wth washers to take up the slack.
