Re: Too Much Oil Pressure?????
Posted by ltf in nc on August 15, 2000 at 13:05:43 from (206.228.214.254):
In Reply to: Too Much Oil Pressure????? posted by Brian on August 15, 2000 at 05:43:55:
The first thing I would do is to substitute a know good oil pressure gauge. Most oil pumps have a bypass built in to regulate the oil pressure. I doubt that this is clogged. Most failures occur with the bypass spring breaking resulting is lower pressure, not higher. It is unlikely that at idle that the tractor would make more pressure than the predetermined relief setting. You do have the correct oil in the tractor, right?
Post A Followup
: Re: Re: Too Much Oil Pressure?????
