Re: Seal replacement ,shafts where brake disc ride Super M
Posted by D Slater on August 18, 2011 at 08:54:59 from (184.15.0.80):
In Reply to: Seal replacement ,shafts where brake disc ride Super M posted by Mike1972chev on August 18, 2011 at 08:28:13:
Not hard, if the covers are off use a slid hammer in the threaded hole in the end of pinion shaft. Plate inside disc contacts will come out with shaft. Seal is in the plate. Plate can also be pried off. If you look close cut outs to get a pry bar in can be found on the outer edge and back side of the plate. Needs to come out pretty even. Plate will have a o ring also.
