Re: Magneto to Distributor Conversion...
Posted by Janicholson on August 18, 2011 at 11:11:39 from (199.17.6.77):
In Reply to: Magneto to Distributor Conversion... posted by Stemmy on August 17, 2011 at 20:45:59:
Purchase a Distributor from a B, BN, A, SA, C, or CS, 100 120 etc.
Do not get one from a cub, or H or M they have differing spark advance curvs.
Remove the mag, and put it on. A 6v coil will be fine, and eventually a ballast resistor can be used to make it OK for 12v.
The ignition button will need to be changed to one from a distributor equipped tractor, as the Mag button is a grounding kill switch, and cannot be made to control ignition source voltage.
A key switch is nice if you want added security.
(just OFF ON)
Put the distributor on the mount, a little timing, and there you are. Jim
