Re: Victory! (carb/governor problems)
Posted by JRSutton on August 18, 2011 at 15:28:39 from (75.130.109.233):
In Reply to: Victory! (carb/governor problems) posted by sean0918 on August 18, 2011 at 15:08:01:
You would be correct.
Law of thermodynamics: increased pressure in a gas = increased temperature. And vice versa decreased pressure = decreased temperature.
So air from going from high to low pressure = cold.
