Re: Victory! (carb/governor problems)
Posted by FC Andy on August 18, 2011 at 15:30:10 from (74.126.84.52):
In Reply to: Victory! (carb/governor problems) posted by sean0918 on August 18, 2011 at 15:08:01:
The manifold gets cold because heat is removed from the air to vaporize the gasoline. Your carburetor has a Venturi in it, this is there to increase the velocity of the incoming air and thereby pull a mist of gasoline into the air. As that mist vaporizes, the manifold will get cold. This is perfectly normal,and expected. Some of the larger gas tractors will actually ice over the outside of the manifold and carburetor in the right conditions. -Andy
