Re: farmall md head job/ valve grind
Posted by sflem849 on August 19, 2011 at 05:38:43 from (69.197.84.39):
In Reply to: farmall md head job/ valve grind posted by jim warehime on August 19, 2011 at 03:36:17:
Carter & Gruenwald has about the best price on the valve grind gasket set. Check with NAPA. I thought I checked for the MD and they couldn't get the set, but when I was there for the WD-9 they could get that one!?!
