Re: I need touch control advice
Posted by tractorsam on August 19, 2011 at 08:55:59 from (24.222.60.206):
In Reply to: Re: I need touch control advice posted by Paul Shuler on August 19, 2011 at 08:07:39:
Most peculiar. I'd still try filling it, running it, removing the fill plug (carefully, beware of the possible pressure behind it) and see what happens.
On the off chance, where are you parking the tractor? Just thinking about sun - heat - expansion and all that good stuff. It might explain the hitch cylinder but doesn't really work for anything else. Sam
