Re: I need touch control advice
Posted by IH fan on August 19, 2011 at 09:43:36 from (108.92.99.106):
In Reply to: I need touch control advice posted by Paul Shuler on August 19, 2011 at 07:46:01:
Without looking at one, or knowing for sure, I find it hard to believe there is no vent somewhere in the reservoir, if only for heat expansion and cylinder movement. In the parts book there is shown an "expansion plug"... wondering if that is actually a vent plug. Some systems I have worked on had a pipe plug with a porous brass breathable insert, and some that had the "wrench square" cross-drilled to breath a little. If one of these was replaced with a standard pipe plug, the reservoir would not vent properly.
Someone mentioned a seal leaking when not under pressure and sealing okay when in use... I have seen that too. If the fluid is getting into the crankcase, the only common seal is the pump shaft seal.
This post was edited by IH fan at 09:46:40 08/19/11.
