Re: I need touch control advice
Posted by Wilks54 on August 19, 2011 at 10:32:30 from (216.207.2.99):
In Reply to: I need touch control advice posted by Paul Shuler on August 19, 2011 at 07:46:01:
I have a C and the touch control is vented at the fill port. A hole is drilled into the cap. Works great. Also sounds like you may have a bad seal somewhere. It shouldn't build pressure once the tractor is shut off.
