Re: WD-9 Gas Line Compression Sleeve
Posted by Janicholson on August 19, 2011 at 10:39:38 from (199.17.6.77):
In Reply to: WD-9 Gas Line Compression Sleeve posted by WD9ER on August 19, 2011 at 10:25:18:
With respect, I would not use copper line for Fuel. It seems like it would be OK, but it can and does work harden from vibration and break off. Purchasing break line tubing, with correct fittings, or with seperate fittings and cutoff ends is good. Stainless Steel is great. I do not like synthetic rubber, or composite lines on gravity fed fuel either. Failure can be very Disastrous. My uncles H was toast from a hose leak onto the starter. Jim
