Re: M Carb Float and Needle
Posted by rustyfarmall on August 19, 2011 at 14:36:34 from (216.248.71.224):
In Reply to: M Carb Float and Needle posted by jw-farmall-m on August 19, 2011 at 14:01:10:
Clean the needle and the seat with aerosol carb cleaner before you install them. I learned to do that on every carb I rebuild.
