Re: Farmall 560 too tall...
Posted by ih560 on August 19, 2011 at 23:52:37 from (63.131.193.36):
In Reply to: Farmall 560 too tall... posted by JRSutton on August 19, 2011 at 10:33:09:
chpmnsws6 said: (quoted from post at 01:56:10 08/20/11) I'm not great with the details, but here is a picture of it-
[URL=http://imageshack.us/photo/my-images/809/farmall1.jpg/]third party image[/URL]
And one of the hills on our lot-
[URL=http://imageshack.us/photo/my-images/801/farmall2.jpg/]third party image[/URL]
Its mowed the 5 acres in about half the time the little ole Massey could. We'll be plowing the field up this fall, and I think that is where this tractor will shine.
I just noticed the normal 560 was a bit lower to the ground (shorter tires), and had a shorter wheel base and didn't know if the swap had been done or was readily available.
Many would consider yours a normal 560, or as it was officially known a Row Crop. You must be used to smaller utility type tractors. Your tractor also has a Schwartz wide front on it with some pretty large flotation tires, it would be shorter in the front if you put stock sized tires on it. As far as the height and length go, it's just a row crop tractor, they are just about all that way, across the different brands.
This post was edited by ih560 at 00:00:37 08/20/11 3 times.
