IH 404 hydraulic question
Posted by Wcroom on August 20, 2011 at 09:33:35 from (75.216.175.190):
Fellas- I sold my dead Super A (OK, it was only crippled, but beyond the point where I could save it) and bought a "63 IH 404. I"m real happy with the 404. Radiator holds water. Doesn"t use oil. Starts and runs like a champ. Works hard.
A little while back, I had a problem with the lift raising. It wouldn"t. I pulled the seat off and took the cover off of the box underneath. I"m assuming this is the hydraulic reservoir. I could see thst the intake line was above the level of the fluid. 2 quarts of fluid later, I was back in business. Good deal.
I have looked all over this tractor and can"t find any other way to check the hyd. fluid level. Am I missing something (Other than common sense), or is it possible that the good people at IH meant for you to have to pull the cover off every time you check or add fluid?
