The drive gear on the crank shaft could be slipping on the crank snout. It is driven with a key. If the crank is broken you should have found that out taking the pulley off. If it spins the starter with no flywheel motion, several things can be wrong, from a bad starter drive, to a stripped ring gear. A crank, broken at the rear main will act that same way. (rare) Let us know what you find, it is a little unique. Jim
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th
... [Read Article]
Latest Ad:
[More Ads]
