Re: Farmall M Gears in front not turning
Posted by Janicholson on August 20, 2011 at 11:31:04 from (199.17.6.160):
In Reply to: Re: Farmall M Gears in front not turning posted by John Lundberg on August 20, 2011 at 11:26:51:
The cam gear is the large gear in the front. If it is not turning, it's keyway is not the issue. It is turned from the drive gear on the crank, That keyway can be sheared, which will cause the gears not to turn and the cranl to turn. Jim
