Re: Farmall M problems
Posted by Janicholson on August 20, 2011 at 11:38:42 from (199.17.6.160):
In Reply to: Re: Farmall M problems posted by tripleccattleco on August 20, 2011 at 11:21:12:
Getting fuel to the carb is not the same as having it get to the air going through the carb.
The main jet is probably plugged up. (internal passages and brass parts.
The screw is used to add or subtract from the main jet flow. If it does nothing the main jet is probably plugged. A soaking level rebuild and blow out of every passage is needed.
Jim
