Re: Farmall M problems
Posted by Brownie 450 on August 20, 2011 at 13:21:35 from (66.43.241.198):
In Reply to: Farmall M problems posted by tripleccattleco on August 20, 2011 at 08:45:38:
How is the float level? If it isn't high enough, it might cause the problem that you are describing.
Best way to check level in carb is to put a fitting in the drain plug & run a piece of clear tubing up along the carb to determine level.
