Re: Farmall M Gears in front not turning
Posted by rustyfarmall on August 20, 2011 at 13:58:10 from (216.248.71.224):
In Reply to: Farmall M Gears in front not turning posted by John Lundberg on August 20, 2011 at 13:52:25:
If you have the pan off, you should be able to look up from underneath and see if the crank is broken, and where it is broken.
Please do not junk the tractor. Let someone else have a chance at saving it first.
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
