Posted by GordoSD on August 20, 2011 at 15:30:25 from (216.106.253.212):
In Reply to: Re: Farmall M problems posted by tripleccattleco on August 20, 2011 at 11:21:12:
In your first post you said it wouldn't idle. Now you say it idles fine but stalls when throttle is advanced. So which is it? The load jet adjustment at the bottom of the carb will NOT affect the idle. That is bad advice someone posted. That adjustment should solve your stumbling problems. You should get just a tad of black smoke when you pull the lever back quickly. That means you are rich enough to get good power and acceleration, and won't ping or overheat a piston.
There are two idle adjustments, mixture and speed. If you turn that idle speed screw in your engine will have to speed up. That screw is opening the butterfly.Adjust the idle mixture screw to cure loping, surging or stumbling problems.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
