Re: Batterys
Posted by old on August 20, 2011 at 15:53:01 from (209.86.226.34):
In Reply to: Batterys posted by JR FRYE on August 20, 2011 at 14:28:29:
A 12 volt battery will in fact make one start faster and easier but if all you do is stick in a 12 volt battery and not do all the other stuff that needs to be done it will cause the points to burn fast and also cause the coil to go bad faster and of course the battery will not charge because a 6 volt charging system can not charge a 12 volt battery to full charge
