Or!!!! the ring gear is broken between two teeth. It is seperate and not actually attached to the flywheel. If it is cracked it will not turn the engine, and that is the problem. To replace it does require a split of the tractor to get the Flywheel off and out. If turning it with a large screw driver spins the ring gear but not the Flywheel, there it is. Ring gears are available new. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
