A couple of the tines are bent. They are usually used behind. Mount them at an angle so they dont mess up the other rows. You need fine soil for best use. Sometimes depending on soil conditions they could be used as a weeder which is their real purpose as the ones normally used behind only have two teeth and are stronger.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
