Re: H starting problem
Posted by Brownie 450 on August 21, 2011 at 08:20:20 from (66.43.241.198):
In Reply to: H starting problem posted by Wyokid on August 20, 2011 at 15:22:20:
Remove the air cleaner cup to check if it has dirt built up to the point that it is shutting off the air flow. Same thing with air intake hoses---a flap of rubber from the inside of the hose can block air flow.
