Posted by Janicholson on August 21, 2011 at 09:12:00 from (199.17.6.66):
In Reply to: electronic ignition posted by flhr62 on August 21, 2011 at 07:47:26:
Excessive is more than .001" up and down and sideways, (not in and out). If the cam bushing is OK, then the Petronix system will be fine. If it is worn, the system will have variability between the magnet ring, and the pickup, if not contact! The advance mechanism and shaft on shaft fit must also be good. Best of luck. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
