Re: H starting problem
Posted by El Toro on August 21, 2011 at 12:20:48 from (108.15.86.54):
In Reply to: H starting problem posted by Wyokid on August 20, 2011 at 15:22:20:
When it quits running pull off a plug wire and see if there's fire to the plug. You need to do this asap when it quits. If there's no fire, I would first replace the condenser and see if the engine will stay running. If there's still no fire you probably need a new coil in the mag.
Hal
