Re: Farmall M Gears in front not turning
Posted by Janicholson on August 21, 2011 at 15:56:14 from (96.24.99.126):
In Reply to: Farmall M Gears in front not turning posted by John Lundberg on August 20, 2011 at 08:55:32:
Turn the engine with a screw driver in the ring gear teeth. If the ring gear turns, I think it will, the engine might be stuck, but not trash. Turning the engine with a bar between the spring towers on the clutch can be effective. THe clutch is in need of being replaced as it is stuck, And doesn't look good. Jim.
