Re: John Lundberg's Ring Gear
Posted by rustred on August 21, 2011 at 16:09:28 from (74.200.18.156):
In Reply to: John Lundberg's Ring Gear posted by El Toro on August 21, 2011 at 16:02:42:
nice to hear end results, as often forgetten once they get a bunch of info. it must have shined up the mounting surface by spinning on the flywheel.
