Re: Farmall M Gears in front not turning
Posted by El Toro on August 21, 2011 at 16:23:44 from (108.15.86.54):
In Reply to: Farmall M Gears in front not turning posted by John Lundberg on August 20, 2011 at 08:55:32:
Does the flywheel move when prying on the ring gear or does just the ring gear move. It may be sliding around the flywheel. Hal
