Re: M and H fronts
Posted by D Slater on August 21, 2011 at 18:15:51 from (184.15.0.80):
In Reply to: M and H fronts posted by P T Farmer on August 21, 2011 at 16:40:17:
If looking at a complete one the arm that bolts to the upper bolster steering shaft has holes that 5/8 diameter bolts fit in. 3/4 bolts fit a M one.
