Re: Farmall M pto
Posted by Nebraska Kirk on August 21, 2011 at 18:38:04 from (207.91.4.138):
In Reply to: Farmall M pto posted by Fixerupper on August 21, 2011 at 18:16:11:
On an M, there is no way to make it so that you can start the PTO without pushing in the clutch and thereby stopping the forward motion of the tractor. You can stop the PTO while moving, just push down on the rod that engages the PTO.
