Re: Tel-A-Depth: Worth saving?
Posted by CNKS on August 21, 2011 at 19:08:22 from (216.144.104.128):
In Reply to: Tel-A-Depth: Worth saving? posted by Moondoggie on August 21, 2011 at 17:46:46:
You can use one of the other valves, not sure whether the existing cylinder will work because it is set up for tel-a-depth. It can be changed. If it was mine I would try to fix it. The other valve will require you to set the height above the ground of the bushhog or anything else each time you lower the hitch. The big advantage of the tel-a-depth is that it returns to the same height or depth each time it is lowered.
