Re: Rust in tank
Posted by Harold Evans on August 21, 2011 at 20:24:53 from (69.136.4.122):
In Reply to: Rust in tank posted by kopeck on August 21, 2011 at 18:21:34:
I've successfully lined a number of tractor gas tanks with a
product called "red kote" or some such. It really does work.
If you follow the directions carefully and thoroughly, you will
have, for all practical purposes, a plastic gas tank when you
are finished with the job. Just don't plan to use it right
away. Let the chemical dry completely before you add any
gas to the tank.
