Re: ta - straight shaft confusion
Posted by ih560 on August 21, 2011 at 20:54:20 from (63.131.193.36):
In Reply to: ta - straight shaft confusion posted by bennymn2011 on August 21, 2011 at 20:28:30:
ta confusion said: (quoted from post at 23:28:30 08/21/11) What is the difference between a t/a eliminator and a straight shaft ?? Do you not need a t/a elimintor with a straight shaft ?? Or is it one in the same ??
Just two ways of saying the same thing. You can't just run a straight shaft through there without some machine work, because the planetary gear carrier Is where the bearings are mounted. All a TA eliminator kit is, is a coupler to connect the two shafts together in the middle of the TA and a carrier without the planetary gears, take out the sprag clutch ( ramp and rollers) and no more TA. It would be straight shafted, as they say.
It would be easy to make your own eliminator with parts you already have in there, but I guess to most people it is worth the $350 for the kit, to not have to mess with it.
This post was edited by ih560 at 21:12:09 08/21/11 2 times.
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
