Re: ta - straight shaft confusion
Posted by caterpillar guy on August 22, 2011 at 05:04:46 from (66.188.53.165):
In Reply to: ta - straight shaft confusion posted by ta confusion on August 21, 2011 at 20:28:30:
Well if you dump the TA, you need the replacement shaft to be hollow. Or the oil flow to the front bearing. The hole is only about 5/16th"s . The oil comes from the pinion gears and flows to the front bearing through that shaft. You will have to do both splits to do this also. At the clutch and the rearend.
