Re: ta - straight shaft confusion
Posted by D Slater on August 22, 2011 at 07:11:48 from (184.15.0.80):
In Reply to: ta - straight shaft confusion posted by ta confusion on August 21, 2011 at 20:28:30:
You don't say what tractor. If mechanical T/A IH made some without T/A. Several parts were changed though. One shaft can't just be added.
If you could find salvage parts from a non T/A and transmission driven PTO tractor in good shape a straight shaft from clutch to input shaft can be used with a splined coupling joining them. On a T/A tractor the transmission input shaft is part of the T/A unit.
IH made some mechanical non T/A tractors with dry center housings. Oil was only in the transmission housing. Not many non T/A tractors compared to T/A ones though.
