Re: Rust in tank
Posted by kopeck on August 22, 2011 at 07:49:56 from (65.18.103.239):
In Reply to: Rust in tank posted by CNKS on August 21, 2011 at 18:57:44:
That makes sense, I couldn't see how you could get 20 gallons in such a small space.
Are the baffles near the bottom of the tank? I would think they would be, I'll have to take a closer look.
I'm somewhat torn on what to do. I called the local radiator shop and he would be happy to do it but due to the divided tank the only way he would work on the tank is if he cut an access hole so he could see all the compartments. Pretty much the more he talked the more the price when up. I know that in order to guaranty his work he has to do what he has to do but I'm not to keen on cutting the tank up.
I also don't want to have to deal with this every other year either.
I'm looking at the POR-15 kit, has anyone tried it?
K
