Re: Super A brakes
Posted by Farmer Bob on August 15, 2000 at 21:58:45 from (208.49.9.34):
In Reply to: Super A brakes posted by Stan on August 15, 2000 at 19:45:13:
Stan, You may have broken the brake band on that brake or maybe one of the connector pins came out of the end of the band. Get under the tractor and use a flashlite to look into the small opening where the brake connector rod goes into the housing. Reach up and move the brake pedal to see if anything is moving inside. You may have to pull the final drive off to really detect the problem. Good luck.//FB
Post A Followup
: Re: Re: Super A brakes
