Re: M rear axle seal
Posted by Jim on August 15, 2000 at 22:12:50 from (199.240.128.78):
In Reply to: M rear axle seal posted by Haas on August 15, 2000 at 16:57:22:
Most of the time when a rear axle seal starts to leak the outside axle bearing is bad. Did you look at the bearing when you had the axle cap off?
Post A Followup
: Re: Re: M rear axle seal
