Re: 544 Farmall Split
Posted by pete 23 on August 22, 2011 at 10:22:44 from (74.32.234.149):
In Reply to: 544 Farmall Split posted by Rick MacGregor on August 22, 2011 at 07:48:29:
You don't need to worry about that front pto gear until you have it split between clutch housing (TA housing) and rear housing. There is a bolt under neath inside under that T shaped cover. After seperating the housings then follow book about removal of lower pto gear and shaft.
