M Brake Drum Removal
Posted by firechief on August 22, 2011 at 12:15:21 from (204.169.4.20):
I am replacing the oil seals on the brake drum shaft on a '51M. How do I remove the brake drum from the shaft to get to the seals? I removed the drum retaining bolt and tried prying the drum off the shaft but it seems the only thing I did while trying to pry the drum off the shaft was to move the shaft in and out a 1/4". Question: Have I hurt anything with the shaft by moving it? How do you get the bake drum off? Thanks in advance for your help. Brad
