Re: NAPA part numbers for points and rotor - International 4
Posted by TheDurk on August 22, 2011 at 16:56:19 from (71.125.72.35):
In Reply to: NAPA part numbers for points and rotor - International 444 posted by Joe Stewart on August 20, 2011 at 16:21:45:
You can cross those IH numbers on the NAPA website (recently redesigned.) Just put the IH number in the search bar on the upper right, click the 'x' box next to it that says "Interchange." For example the number 407018R91 yields ECH CS1600 which is the same Echlin point set I have been using in my 140 for 30 years.
www.napaonline.com
This post was edited by TheDurk at 16:57:14 08/22/11 2 times.
