Re: John Lundberg's Ring Gear
Posted by El Toro on August 22, 2011 at 17:31:41 from (108.15.86.54):
In Reply to: Re: John Lundberg's Ring Gear posted by Janicholson on August 22, 2011 at 08:34:40:
Spinning that ring gear has probably ruin the surface of the flywheel where the ring gear was a press fit. He's thinking about selling it. Hal
