Re: f-12 It's all done now she won't start
Posted by F14 on August 16, 2000 at 03:56:18 from (216.252.28.87):
In Reply to: f-12 It's all done now she won't start posted by Carl Holloway on August 15, 2000 at 18:43:49:
If it smells flooded, you'll never in this lifetime crank it hard enough to get it dried out and running. Check your float setting, and don't over-choke it. If your fuel pump is questionable, set up a temporary gravity feed using a lawn mower tank to feed the carb. Check to see that you're getting a good hot spark at the plug. I've been known to heat the plugs up with a propane torch to dry them out and clean them up. It helps. Double check to make sure you have the valve lash set right. If one or more valves aren't closing all the way, you get little or no compression, and it won't start. Once I got my carb tweaked right, the mag timing spot on and the plugs cleaned, mine will usually start in one or two cranks. [Unless someone I'm trying to impress is watching ":^( ] I use the following procedure: 1. Fuel on 2. Trans in neutral 3. Mag advance to just over half-way 4. Crack the throttle just enough to put a little tension on the spring. 5. No choke unless it's quite cold, say 40 degrees or less. 6. Crank slowly until it comes up on compression, just before the impulse clicks. You may go past a couple of times until you get a feeling for where this point is. 7. Pull up sharply. 8. Repeat 6 and 7 until it starts. If, after a couple of good pulls, it doesn't at least fire, try ONE PULL with the choke on. It's easy to flood, and when you do, you might just as well go have a cup of coffee until it evaporates. Hope this helps. Let us know how you make out.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
